If thats an L71 it should have a flat pancake type sheath, not a folded sheath.Im honestly not sure if this is the exact sheath for the knife, as it doesnt seem to fit properly, both in blade and buckle size.
Beautiful knife.Gonna need to send this off to have a proper sheath made one day. Can't remember for the life of me where I got it from.
View attachment 3198117View attachment 3198118View attachment 3198119View attachment 3198120
The question he is asking is why only serrate one side and not from both sides meeting at the middle edge…
I understand the problems. Would be interesting to see how a double-bevel serrated would cut, in comparison.But I can answer why *I* don't do it. My post above is one reason. But now that the concept has been presented to me, the other reason is that I grind each serration individually using progressively finer grits on my dremel. It's all done freehand. I think it would make it significantly more challenging to keep the apex of each scallop perfectly in line with each other trying to grind serrations the way I do, but with a bevel on both sides. Actually it's funny you should ask, because I keep thinking about how it might be an interesting experiment to grind alternating left and right side bevels on a serrated knife. But the problem (in my mind at least) that keeps me from doing it, again, is consistency. I rely on all the bevels being on the same side in order to create the crisp pointy apex of each tooth. Were I to grind alternating left and right bevels - or try to grind a double bevel such as those you inquired aboutAardvark , my concern is that I would find myself "chasing" the point, removing too much material, and ending up with something sloppy looking.
Of course, that's not to say the experiment won't happen at some point. But I have lots of things to work on before that.
Espero que tengas juntas de repuesto a mano
David, how's the grip x been holding up? Any complaints or issues with longevity or heat?
Thank you, I want to check it out at at some point. Fine looking blades as usual sir.Well, I carry one next to my skin, as a neck knife for the past year or so, and it is still rocksolid (pun intended). I also have been carrying one on my belt since the end of January, and it is good to go.
I have received none.
