Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Here's what that mod looks like, the belt loop swivels on that copper rivet, allowing you easier sitting, less jamming the knife into a chair or car.
Notice the small hole in the leather, worn through from putting the knife in and out so many times, but, it doesn't affect the retention and I do not see a good fix for it, so, it's just there
Untitled by GaryWGraley, on Flickr
The hole in the leather is tight on the rivet, otherwise as you peen the end, it could make the rivet bend,
I put the peening end of the hammer over the hole and take my leather mallet to hammer that down into the leather, it leaves a dished shape to the leather and allows the head of the rivet to sit flush with the leather.
The initial belt loop I glued together to make it a solid piece, as I also did the new belt loop where the rivet goes through is glued as well.
And that is something I learned a long time ago from Rob Hudson while at an Ashokan Seminar many many years ago !!!
G2
Untitled by GaryWGraley, on FlickrThe hole in the leather is tight on the rivet, otherwise as you peen the end, it could make the rivet bend,
Untitled by GaryWGraley, on FlickrI put the peening end of the hammer over the hole and take my leather mallet to hammer that down into the leather, it leaves a dished shape to the leather and allows the head of the rivet to sit flush with the leather.
Untitled by GaryWGraley, on FlickrThe initial belt loop I glued together to make it a solid piece, as I also did the new belt loop where the rivet goes through is glued as well.
Untitled by GaryWGraley, on FlickrAnd that is something I learned a long time ago from Rob Hudson while at an Ashokan Seminar many many years ago !!!
G2
