Sunwayman V10R, well less than $100, high output (for the XM-L option) but easy accessible user interface. Use the power of RCR 123A's and you're set.
I've used the SWM M10/V10R form factor for more than 3 years - it's on keyring and I never leave home w/o it.
I'm assuming you mean the new H52w headlamp? If so, I just picked up one, and to say it's an impressive light would be an understatement...especially if good neutral tint is important to you. I already have the SC52 and SC52w and wanted this since it's essentially the headlamp version of these using almost the same wonderful UI & driver, except in this case the tint on the XM-L2 emitter in the H52w (which I assumed would be the same slightly yellowish/green 4400k tint as the SC52w), turned out to be one of the best neutral tints I've ever seen this side of the (CPF flashaholic's grail: Nichia 219)!
Very slight rose tint with NO undesirable green with big hotspot and huge spill beam pattern and...one of the best, almost w/o fault, of any single cell AA, Ni-MH, lithium primary, or 14500 LI-ion light I've owned...and I have a bunch. It's hard not to gush about this little headlamp (or 90degree angled EDC if you want) it's that good!
EDIT: To the OP...pocket size EDC to me means single cell CR123/16340 or AA/14500 lights. My current favorites are the (1) Zebralight SC52w, (2) Tie: Jetbeam RRT-01/Eagletac D25c...and distant 3rd place the Sunwayman VR11 all now updated with XM-L2 emitters and all capable of sub/1 to 3-lumen moonlight modes and well in excess of 500/600 lumens for short periods on max using Li-ions.
May I ask why you put the Sunwayman V11R well back of the Jetbeam? I've had the RRT-01 for some time now, and while it's a nice light, I actually prefer the V11R for actual use. The fact that my RRT-01's beam looks like it's shining out of a green pond and the V11R has a very nice white tint may be a big part of that, though.
knolan,
Thanks for the info. I guess the tint lottery is a hard one to win -- just keep buying until you get one you like!
Do you use rechargeable cells? If so, do they drain on their own for you? I find that both my 14500's and 16340's will need charging after sitting for a day or two after being fully charged. Maybe I need better batteries -- it would be nice to know my cells are at full charge when I grab them after sitting for a few days.
I've had the misfortune of dropping my RRT-01 a couple of times, and it's gotten really dinged up from hitting the pavement. The last time it happened I had to get out my Sharpmaker rods and smooth the edges down, so they wouldn't cut holes in my pockets.
