I will NOT flame the Surefire brand, however, I would be remiss if I did not encourage you to look at other brands as well. I would look at
Flashlight Reviews.com and look at his reviews. Are they perfect? NO, but they are very detailed. Also, read some at candlepowerfoums.com (mentioned before.)
I have owned 2 SF lights and now own NONE. I sold both of mine (E1e and E2e) and have moved to the Nuwaii Qiii for EDC and the Streamlight Tactical TL3 (luxeon bulb) for the BOB situation. I have spent less on those two than on the SFs and will have TONS more power.
There are MANY different manufacturers that you will run into and you can spend an obscene amount of money on them. I ran into the same problem that you are seeing here - you ask for a good flashlight and someone suggests a $200 light. Might be alittle extreme to begin with.
Others have suggested the G2 (GREAT light - even a better value) take a look at it. The power of the E2, only rubber instead of metal. Look at the Nuwai line, the Streamlight line, the Inova line, the Peak line, the new Gerber line, PentagonDefense lights...the list can go on and on.
As with a knife purchase - decide your needs/use, size requirements/restrictions, budget - then go looking. Rank those needs in order of importance, because there will be options in all of them.
Good luck and I personally welcome you as the newest member of THIS 12 step program!
David
