<font face="Verdana, Arial" size="2">Originally posted by BARRY JONES:
Other than what has already been stated, this is what I have to add.
If you take 3 blades ground to the same edge thickness (1 hollow, 1 flat, & 1 convex) , heat treat them all the same, and sharpen them all the same, how can you say that the hollow ground blade will be "sharper"? It is my humble opinion that the sharpness has to do with the type steel, heat treat, and the molecular composition of the steel. (If I am wrong then please correct me). I just can't see that hollow grinding the blade makes it more sharp than the others.
</font>
Barry --
If the very edge is the same, then I agree, I expect them all to cut the same, provided I'm cutting with just the very edge. In many materials, I won't see any difference in performance -- although the user may see a difference is difficulty-of-sharpening, when it comes time to resharpen (the flat grind will have more metal to grind away).
But cut a little deeper in binding materials, and in the hollow ground case, there's less metal behind the edge to push through the material. In the flat ground case, the amount of metal is increasing linearly. Again, in many materials, you won't notice a difference, but in some materials you might.
Lastly, keep pushing through a very binding material. When the material hits the non-linear expansion of the hollow grind, it tends to wedge. The flat grind tends to shear the entire way through.
db posted a contrary position, but I'm not sure how contrary it is. I am over-simplifying somewhat when I say it's just deep cutting that makes or breaks hollow vs. flat grind. It really does depend on the material, but I can't quantify it better than that right now. If the material is especially hard and especially binding, then it's really easy to see the difference when deep cutting, in my experience.
If I can find some time, I'll do some experiments with a delica and calypso, both sharpened to the exact same edge, and come up with some concrete examples where the performance characteristics don't match.
