Devin,
What kind of heat treat would you suggest?
What do you think of AR500 as a platen?
Thanks
Steve Hostetler
Find some broken HSS circular saw and cut piece in dimension you need. It will out last every regular steel . . . .Hi Guys, could you please advise which would be the more wear resistant steel for the back plate on a platen? I have some 01 and some A2.
Thanks
I use ceramic tile from the home improvement stores.
It is cheap and doesn't conduct heat like steel.
I typically get 6 to 8 months out of one before it starts to dish.
Been using tiles for several years now.
USA sells precut fireplace glass. There are other suppliers available in BF posts as well. You just epoxy it to the steel platen. Amazing at conducting heat. The platen stays cool to the touch regardless of how long I grind or how much pressure I use. As I recall it cost about $30. But I have seen pairs available for $24. Frank Niro invented this in like 1990.How do you attach it to the platen?
I've found that using 3M double sided tape Heavy Duty Strength is good. You need to have a small lip or shelf on the bottom of the steel platen to keep the glass from being pulled down and off. I drilled a couple 3/32 pin holes and ground them flush with the bottom of the glass. The nice part about the tape vs JB Weld is that you can use a heat gun to soften the tape and it pulls off easy no grinding left over epoxy or JB Weld.How do you attach it to the platen?
Floor tile?
Hoss
