break free works great, I find the fluorinated grease actually gums up the action after about a week of carry.
Careful with the break free/clean. I work as a Millwright and it is extremely abarasive and can cause pitting in certain metals.
Found this on a Smith and Wesson blog
"You must remember to re oil the gun after using brake cleaner. It removes all of the oil from the pours of the steel and can cause the gun to rust internally. (Even stainless steel.) This requires you to disassemble the gun to get at the internal parts and defeats the purpose of using the aerosol cleaner in the first place. I've seen a few police guns ruined by using gun scrubber type cleaners and then not properly lubing the gun. My advise is to stay away from this stuff all together. It's a lazy mans cleaner and ends up being more work than regular CLP or Hoppe's on a rag in the end."
Have personally seen it etch a friends glock, handle. Brake clean has been known to remove bluing.
Saw a buddy do it as quick clean in the Army back in the early 90's. It literally destroyed his weapon M16A2 in about six months. Bluing was shot on the barrel, ate his pistol grip and pitted the hell out of the bolt. He would clean his weapon and then not properly oil it down afterwards and Georgia is too hot and too humid to leave any metals exposed.
As far as industry use goes, we were rebuilding some gear boxes and cleaned the gears for inspection before installation. Did some non destructive testing to ensure no cracks, whistle blew, went home. Came back to work on Monday to find almost the exact senario as described. Where the gears were dry, rust was starting to form and pitting was starting to occur. Fortunately we were able to clean them up and re lube and use with out further damage. The gears were made out of a high tempered steel.
Brake clean that is clorinated will eat any wood inlays.
Guess you can use if you need to, just lube very well when done, although I wouldn't recommend it.
Like the posting said it literally removes all oils out of the metal and it can make it more inclined to rust if you don't properly lube afterwards.
Hope this helps.
Tom
Brake Free is very similar to brake kleen, on their website,
http://www.break-free.com/?location=/products/index.asp
they state "DO NOT APPLY TO RUBBER OR PLASTIC GRIPS OR PARTS. Remove promptly with a cloth to avoid possible plastic damage. Powder Blast may damage painted finishes, camouflage or wood finishes and most polymers. Use with caution. "
CLP is awesome stuff, my spec ops buddies swore by it. That is definitely ok to use. It is not nearly as corrosive.
I just picked up an Umnumzaan and think that any break free/clean /kleen would hurt and damage the o rings that make it close O so nicely.
Good luck, hope this clarifies things.
Tom
