I have used a roller (that comes with the stainless steel wrap roll ..i buy 2 feet x 100 feet at a time) ...same thing as a roller you would use to do wallpaper with. it's plastic. I generally use that on the long side of the envelope. I fold over twice....3 is recommended, but kinda overkill. then folding over twice on the ends, i use a HAMMER and hammer the envelope shut to as flat as I can get it.
NO NEED FOR PAPER TOWEL INSIDE!
Or paper anything. Eventually it will cause the envelope to expand. Degrease your blades well and if you get all the air out you can, the steel should be the same color as when you put it into the envelope. Especially if you're plate quenching (which i don't do as it can use some undesired things going on)...can keep the blade straight but...the blade can also warp left to right or right to left causing a curve..generally on 1/8" stuff or thinner. Plate quenching also does not guarantee a straight blade. if your crimps are thicker than the blade itself, then you might get some warping.
I prefer to take the blades out of the kiln, wait till all the visible red heat is gone...then cut open the foil packet, check for straightness and then hang to still air cool. will still achieve hardnesses of 65-66 prior to temper. temper twice at 500 for two hours and you'll get about 60-61 assuming your austenizing temperatures of course. if the blade is warped, then i use my vise with some aluminum jaws and with the jaws opened about 1/2" inch, i put light pressure to bend it to straight.
any discoloration in the steel is caused by oil left on the blade. No biggy...you can sand it off.
When you have flaking of the steel, then that's BAD.
if you had a hole in the envelope, you'd have some decarb for sure. try grinding it down .001 or .002 and test again with
the file.
while i was writing this, METE apparently beat me to it!
