Basically, if you use the knife in the manner for which it was designed, no properly made lock should give you trouble.
Watch out for that Bearing lock they can roll off and fail. I have seen it. I also think there is a youtube video on it. If an Axis lock or a frame lock by a decent maker isn't good enough for you then you need a fixed blade.
Cold Steel's version of the lockback called the Triad seems to be reigning champ judging by the videos I've seen Demko posts.
http://www.youtube.com/watch?v=DnbK2r2u6A0
Sal has said when they tested their compression lock, the pivot pin broke before the lock...can't get better than that.
That just shows one lock type and only proves it is fairly robust. It doesn't prove it is any better or worse than any other lock type. As I mentioned it gets its strength over a standard lockback by transfering the forces to a stop pin and then to the liners. Many other lock types do the same thing.
That's true, I would love to see other makers knives try and match that. :thumbup:
People can say what they want but right now Cold Steel has them all beat hands down, no contest with their Tri-Ad lock when it comes to pure strength of the lock.![]()
Knowing how an AXIS and compression lock works they should be able to handle the same amount of abuse that knife was subjected to. You only have part of the story in that video. You won't see it from Spyderco or Benchmade because they have a marketing strategy that does not involve spandex, pigs, and bamboo.Although Spyderco, and probably Benchmade, test their knives to destruction they do it behind closed doors and we won't ever be able to watch.
I'm just joking around so no one get bent out of shape and turn this into a peeing contest.
In addition to the stop pin the Tri-ad still has the pivoting pin in the lockbar. The Tri-ad lock under failure load the stop pin has to shear and the lockbar pivoting pin also have to shear in order for it to fully fail. I'm referring to the Tri-ad of course.
That basically means it is stronger than the Axis IMO![]()
Yes but the pivot hole in the lock bar is oversized to allow for wear in. So without the stop pin there would be a lot of slop in the lockbar and I don't see that being strong and holding very much. It gets all it's strength from that stop pin which transfers forces to the liners. And it is not the only design to do that.
I don't know how the lock would actually act with the stop pin removed, I'm not sure anyone does.
But I would suspect that the extra 'slop' designed into the lockbar pivot hole would allow the blade to close some (15 deg?) past normal. I also suspect that the first time it is knocked around that the lockbar would jump out of it's recess and it would fail. But I guess if you have experience with something very similar then it's possible it wouldn't fail that easily. I still wouldn't trust it personally.
Regardless, you shouldn't be beating on a folding knife that hard anyways and if you are, you are talking a calculated risk that involves the removal of your fingers. I like my fingers so I would find something else long before that.
