JTR357
- Sep 10, 2007
My vote goes to the framelock and lock back configurations.
- Mark
- Mark
It gets all it's strength from that stop pin which transfers forces to the liners. And it is not the only design to do that.
What other lock transfers forces to the stop pin to keep the blade in the open position?
The strongest lock is the one you don't have. Fixed blade.
Otherwise, balisong. After that, I'd say framelock, followed by by a tie for the axis and caged ball bearing lock. I say framelock because the strength of the lock to hold the knife open is dependent upon how tightly you grip the knife; of course that point is moot if you have the grip strength of a baby.
Compression lock. The lockbar wedges itself between the blade tang and the stop pin. Forces are transferred through the lock bar to the stop pin.
AXIS lock. I guess I could have elaborated. Closing forces are not transferred to the stop pin like opening forces are. But the tang pushes against the AXIS lockbar which is like a bigger movable stop pin. Regardless, the forces are transferred to the metal liners.
All the AXIS variants all transfer force to a component which eventually gets distributed to the metal liners. There are probably some other ones that I don't know about or I am forgetting right now.
friction folders and balisongs are the best locks there are. both require your hand to fail before it will close on you.
I don't think it is a can of worms. There are pluses an minuses to every type of lock. My own opinion is that the frame lock is the strongest but it is also one of the heaviest. The sliding tang locks seem to be quite strong but they are more prone to failure because they use several parts, including springs. Lockbacks are quite strong but sometimes make the knife harder to open than other types. Basically, if you use the knife in the manner for which it was designed, no properly made lock should give you trouble.
They don't need all that, just hang about 500 + lbs off of them bad boys and see if they can take it.
And do it on video and put it out there for everyone to see.
I wouldn't hold my breath waiting for that to happen though.
If they say they are strong they need to put it out there and prove it.
They can talk about it all day, but that doesn't mean a whole lot IMO.
Since the OP is a gold member, he CAN search. This subject HAS been discussed many times.
