Kershaw makes a bunch of knives that open with a assisted opening flipper for index finger opening, sell on-line < $100 and have blades of 2.5 to 3" in length.
I have liked the Kershaws I have seen, thx!
Kershaw dimension comes to mind. Titanium handles, assisted opening, and push button lock. Discontinued, so get one while you can.
Just had another thought. Look at the Opinel twist locks, either #6 or #8 depending on the size you need. Easy to open and the twist lock is secure and easy to close. I'm thinking about the same thing as I too am developing arthritis in my hands. I've used either a round file or Dremel sanding wheel to open up around the thumb nick to make them into the old style easy openers - can make it as large as needed. Also Opinels are dirt cheap (inexpensive, but robust). Just a thought.
LLAP
Rich
Another vote for the mini-Griptilian by Benchmade. The axis lock is easy to use, smooth and strong.
Jim
Uh...is this a Spyderco? Sorry, don't know the model. I have wanted an excuse to get into Spydercos, however.
Hogue makes a button lock that starts around $90. That seems like the easiest to manipulate.
It's a shame OTF gravity knives don't really exist any more.
I do think that a fat handled, easy sheathing fixed blade with a sheath that spring clips over your pocket or waistband is the most useful choice. No belt or fingers necessary:
There's a good reason this is the normal work knife in Scandinavia.
I don't find Spydercos very easy to open. It's such a long arc from the center of the blade hole compared to a stud. Makes for a more complex motion.
I too have arthritis in my hands and some days they are pretty sore and stiff.
I've found, for me, a Spyderco lockback knife with the round opening hole works best for me. Or the small Benchmade MiniGrip with the thumbhole. The Minigrip opens very easy do to tbe axis lock. Which is quite strong and easy to disengage too. I like as well that the handles feel fuller to me, making them easier to grasp. Especially when my hand is cold or wet.
For a Slipjoint pocketknife, look for an Easy Open model. The EO notch allow the blade just to be pinched and pulled open. And some are quite easy on the pull. If you're curious about those, you can check the traditional forum for specifics. Very helpful there.
Both decent used MiniGrips and Spydies pop on the exchange quite regularly.
