Force One
PT-5
Nark
Busse's fierce knives
desuker: sweet!!! So what are your thoughts?
The more I look at pictures of it I'm thinking I could baton the front part of the stine as it looks very think. If I had to.
Are those SF handles similar to that of the SFNO?
Yup...same slabs as the SFNO's...
Here's two Force One's that I have... one with a special tip grind....
(snip)
Hope that helps!!:thumbup:
I had one, but ultimately sold it. When I first got it, I liked it alot, but then found others calling my name that likely would be more practical and see more use. That is why I eventually got rid of mine. I personally did not find the americanized tanto to be very utilitarian, so in a world of limited resources, I finally sold it.
Breaking anything on it is highly unlikely. The tip is massive. As you mentioned above, I think the knife was meant as a fighter. I will say this--while it does not have the greatest reach, when you hold it, the average response you can expect is "Oh my ******* God!" It is a scary looking blade. And as I recall, weight and balance was nice.
Good luck.
I'll bet you regret getting rid of a certain military overrun![]()
Were the Force ! asymetrical?
rbmcmjr: great pics. Thanks for the info. I am still trying to find out if it is CA legal. Is the band breaker make it a double edged knife?
According to local law enforcement, officers disgression.It could be a double edge, or since the top edge stops before the tip, its not. Depends on who you find here. Same applies with "grey area" knife laws such as swedged knives, balisongs (contrary to popular belief, they are not specificaly named as illegal) and blade length, is it measured to the handle or is it simply cutting edge.
Also, there seems to be two different F1's out there. One type with the front edge ground way back through the coating and an abrupt corner where the tip translates into the belly. The other isnt ground at the point, the coating is still intact, as in the pic that Dave posted, and the transition between the tip and belly is more rounded. Wonder what the story is on those? Seems to be a lot more of the sharp transition, tip ground knives out there.
Naaaaa, I like sharing the wealth. In all my trades and purchases, I've only had one potential regret, and I am not sure that it rises to even that level. And in the case of the blade you are referring to, at least I know the guy who got that knife is enjoying the H*** out of it!:thumbup: :thumbup: :thumbup:
hey, I just noticed that the butt of the force 1 looks like a little man in the boat.:thumbup:
