DeadboxHero
- Mar 22, 2014
Good Job Man, proud of you.An update for you guys. I put a good bit of money, and a ton of work into it, and built my own heat treat kiln. I used a lot of red beard ops. Designs, but changed a few things around. I made the inner chamber smaller, it's still long but only about 4x4.5 inches wide. I couldn't put as much insulation on the sides, because of the width of the angle iron I used to make the frame, and the amount I had to work with. That's the main thing I would change if i could.
I had to use 110 volts, and I could only find 18 way kanthal, so I decided running two coils in parallel would be my best bet. Used an auber pid. The one that has the ramp function. So if I really wanted to I could anneal.
I managed to get it up to 1950 to heat treat my 10v knives. I plate quenched in my modified woodworking vise, that I cool before with dry ice. Then got the knives into a dry ice slurry as quickly as I could following that.
I'm currently working on them now. One I ground mostly before hardening. The other I only profiled before. To see which I will prefer in the future.
-Shawn
