- Apr 13, 2007
Do you think either method produces an advantage over the other, I read this passage and it's got me wondering ?
What is a hand-forged knife?
In my shop, a hand-forged knife is one who's blade is forged with to shape with a hammer, on an anvil. The blade is then heat treated, ground without the aid of jigs or rests and fitted with a handle and other fittings one at a time. I use no molds, no dies, and no templates. The finished product is the result of a close partnership between my hands and my eyes - that’s it. Each knife is therefore, truly one-of-a-kind.
The forged blade...
All of my blades are hand-forged. A forged blade is superior to one made by stock removal for several reasons. (A stock removal blade is made by cutting, grinding or machining the blade from a section of bar stock.) The first is that the forging of the blade is really an integral part of the heat treating process. The cycling of the steel up and down from high to low heat as the blade is removed from the forge to the anvil causes the grain of the steel to be reduced. Similarly, the manipulation of the steel with a hammer or hydraulic press mechanically breaks down the grain of the steel. Since, for all practical purposes, smaller grain is superior to large grain, the forging process is able to push the performance of the steel beyond what is capable with a stock removal knife. Now, I will say that some steels, particularly the high-tech stainless steels will not respond well to this type of thermal cycling and this makes them better candidates for stock removal work.
The forged blade...
