Four 8" Shivs and two Field Knives, 3V, SOLD
Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
Feedback: +143 / =0 / -0
The Shiv is made of CPM 3V. It is an 8" modern combat fighter that is built to tolerate extremely rough use in demanding environments but is thin enough to cut. It was originally developed as a combat knife but has also been popular with pig hunters.
THESE ARE SOLD, THANK YOU
Some of these have a double edge point.
The edge thickness before sharpening on these was .015" and it was sharpened at 20 degrees per side, so they are meat eaters. But you can really wail on it, you're not going to break it.
See video below.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of ¼” 3V with a heat treat that has been optimized to maximize edge stability in insanely rough use. The blade has a swedge grind that creates distal taper and deep fullers that, together with the skeletonized tang, create a relatively light weight package (10.7 oz) that is supremely well balanced with thoughtful and deliberate distribution of mass that gives it a surprisingly light and lively feel in the hand without sacrificing tip strength.
The steel, Crucible CPM 3V, is a high performance particle metallurgy super steel with extremely high impact and torsional toughness. The heat treat has been tweaked to improve edge stability and edge retention. In this application it will easily tolerate abuse such as aggressive prying, punching holes in sheetmetal, cutting iron wire and even chopping through cinderblock. It is not stainless, but it has pretty good corrosion resistance.
Specs for the 8" Shiv:
CPM 3V, tested 60 HRC, .235” thick at ricasso
Total length 12.75”
Edge length 7.5”
Weight 10.7 oz
Extra grippy 3D machined scales
Black oxide treated 18-8 stainless steel fasteners
David Brown Kydex sheaths with TecLoc are custom made for these knives and are well designed and well made.
There are two Field Knives and four 8" Shivs in this sale.
1.jpg~original
2.jpg~original
3.jpg~original
4.jpg~original
5.jpg~original
6.jpg~original
7.jpg~original
8.jpg~original
9.jpg~original
10.jpg~original
Rather than just take my word for it I made a video to illustrate the unusual durability of this knife:
[video=youtube_share;jAFQAp3Fo9I]http://youtu.be/jAFQAp3Fo9I[/video]
#1 is a fine ground Field Knife in 3V at HRC62, black micarta scales with red liners, sharpened 15 DPS $260 SOLD
#2 is a fine ground Field Knife in 3V at HRC62, black micarta scales with red liners, sharpened 15 DPS $260 SOLD
#3 is an 8" field grade Shiv in black micarta scales. $295 SOLD
#4 is an 8" field grade Shiv in black micarta scales, the point is double edge and cuts in both directions. Not legal in some areas. $310 SOLD
#5 is an 8" field grade Shiv in black G10 scales. $305 SOLD
#6 is an 8" field grade Shiv in black G10 scales, the point is double edge and cuts in both directions. Not legal in some areas. $320 SOLD
If you want a different sheath I have SpecOps Combat Master Sheaths in their standard colors. They are M.O.L.L.E. compatible and jump certified.
Shipping in the USA is $5.
These knives are unusual because they are machined. I do this in my shop on industrial CNC machine tools. A WIP thread documenting their construction can be found here: http://www.bladeforums.com/forums/showthread.php/1048443
I take paypal, cash, check or MO.
First come, first serve, based on post in this thread. "I'll take it" gets it.
Thanks for looking,
Nathan
I will take the following:
Thanks!
I will take #2 "fine ground Field Knife in 3V at HRC62, black micarta scales with red liners, sharpened 15 DPS $260"
Tim W.
Man, I really love those Field Knives. They go quick! I've got to be faster. Is there a chance you will make any more in Elmax?
I'll take #6 is an 8" field grade Shiv in black G10 scales, the point is double edge and cuts in both directions. Not legal in some areas. $320
ffs, Rolf! Just buy one already.
I'll take #5 if it's still available.
Hi Nathan, I tried to reply to your PM but it appears that your inbox is full. Should the PayPal payment be a goods and services transaction?
Sorry about that. It seems like every time I clear out a bunch of space I get fiddyeleven messages all at once...
Yes, goods and services.
thanks,
Nathan
If you dither you loose out on Nathan's knives and you surely don't want to miss out if you don't have one. I dithered and missed a Field knife I've been waiting for.
I received my shiv. It feels great in the hand and I'm looking forward to giving it a good workout. Thanks!
Beat the piss out of it and send it back for resharpening.
My standard warranty on rough use knives such as the Shiv is if it ever fails for any reason short of intentionally breaking it, I will replace, repair or refund. Broken tips are repointed, damaged scales are replaced with a material of my choosing. You can throw it and you can baton into anything you want, it's covered. It is built and tested to tolerate extreme use.
Wow, you can't ask for somebody to stand behind their product anymore than that, that's a heck of a warranty! While I do not predict chopping cinder blocks with the shiv, I do predict getting years of use out of it. Thanks again!
