I went through about 4 of these back in the day. I had some lock issues with all 4 of them. Lock slipping, not going over far enough and allowing vertical blade play were the main problem.
Also, use the right tool for the job, and use some common sense and your lock wont fail.
benchmade pinnacle is a framelock that has no cutout. its very easy to unlock.
I find it interesting that there is so much emphasis on the thickness of the Titanium, when actually, the failure of a lock will most likely happen at the lock interface with the blade.
like people who think old cars from the sixties are safer than new "plastic" cars because they're all steel. I saw an old gto and a newer Camry get into an accident, and the gto's passenger compartment was a disaster, whereas the Camry was fine minus some crumpled body panels.
Note the cut out is on the inside, it is stronger to do the cut out on the out side, as the force isn't so direct that it bends itLike this one?
Let me get this clear, cutouts on a titanium frame lock are a bad thing if you intend to smack the back (spine) of the blade with a significant amount of force or impact loading.
If that's your thing then stay away from Ti frame locks.
I imagine having no cutouts won't help much under such conditions and few folding knives will stand up to such conditions.
Why?
Because knives usually have a cutting edge and that edge is designed to be pushed, sometimes with a sawing motion into whatever sensible material is being cut.
With a frame lock his generates forces on the blade which apply no force at all on the lock bar (or an insignificant amount of force) so, under normal usage the cut outs in a frame lock will never be exposed to enough compressive loading to cause a failure.
The cut out may be a stress riser but again only of concern when applying heavy abnormal compressive loading which the system was not designed for.
It's like criticising suspension bridge cabling for having poor compressive properties.
Not true. The Pinnacle's lockbar is hollowed out on the inside. There's a groove about an inch long on the far end. If you owned a BM Pinnacle, you'd know that.
