Stop and observe often. The belly is the toughest spot to maintain a flat bevel freehand as the contact area is so small. Some of the increase in bevel width is likely due to increased wobble as well as the primary being thicker.
Indeed. To me, that is the single biggest challenge of freehand that I am facing right now: getting the belly and point sharp and keeping the edge bevel in the same approximate range as the straight portion of the blade. Conceptually I'm clear on what needs to happen after watching the videos. However with a large belly area, it's quite tricky to do that gradual handle elevation throughout each stroke, and do that in a precise and repeatable way that keeps the same angle, time after time. It seems like it's simple math: the more strokes you make, the more you increase the probability of "wavering" or not holding the precise same angle on any given stroke, thus boogering up your previous work and actually reversing your progress.
I similarly had challenges with setting my secondary bevel, or "scrubbing", when I get around the belly area of the blade. It's the exact same issue, and in a way even more complex, because you have to keep changing the elevation of the handle and then scrubbing at that elevation, then rotate blade a little bit more, elevate a little bit more, and repeat. It doesn't feel like a very precise operation, at least not when I'm doing it.
