I have no problems sharpening a knife to hair whittling sharp. Some alloys take more time than others, and some that are more degraded will take more time as well. Some perform better with a more toothy edge and more or less frequent touch ups, some more polished and with more or less frequent touch ups.So here's the question I think that really underlies everything in this thread, maybe I should just ask it directly.
Is it possible for an average hobbyist knife sharpener to get good enough at freehand sharpening to put seriously good edges on your knives that are MUCH better than factory, with just a set of good diamond or water stones, and a strop? Or are we kidding ourselves? I really don't know. Do I need to just practice harder with a bunch of cheap knives and put more time into it? Trying to figure out what it is that gets you to the next level. All things being equal, I'd still PREFER to get good at freehand sharpening, but it just isn't happening.
Stamp made a comment regarding the edge setting of such steels to the effect of "...avoid diamonds as they are likely to over chip the steel due to less than ideal HT". Search for the term martha stewart on his forum for the full commentary.
All of this being said, I like to think that DMT coarse through extra extra fine, a loaded strop and some diamond paste will work for just about anything out there.
Thanks for your post. A question I had is if I'm not getting hair shaving results after my C and F stones--the basic steps--is there any reason to think I'll be able to get the knife actually SHARPER by going to EF, strop, etc? I used to think so, but lately I've seen some folks here and on videos saying you really should be able to get the knife scary sharp even on the initial coarse stones.
So David: you think I probably used too much pressure? I tried the technique of the guy in the video, I was doing it one-handed rather than pressing/guiding with my support hand. I do think I got a pretty good edge, it's super sharp and comparable to my Wuesthofs in cutting food, but it will not shave hair. All I did was follow the video steps, doing the de-stress and shaping on my DMT C stone, then did the sharpening slices on my F stone.
Ok good advice. One good thing is I didn't have any burring last night--I was a able to avoid that by doing what the guy on the video did. During shaping: a few back-and-forth scrubbing strokes (like 2 or 3) at each section of the blade, then flip it over and repeat. During apexing: alternating single slices on each side. I was pressing LESS hard than I have in the past, but perhaps, still too hard on reflection. I do think I've always tended to be an excessive pressure guy. There were indeed very rough/ragged edges (though no burring), so perhaps that is still my issue.
I actually felt modestly good about the result I got following this technique for the first time, the cosmetic look of the edge was fairly even and consistent (compared to some that I've butchered in the past--ugh!) and the real thing that matters--the cutting performance--was right there with my Wuesthofs and MUCH better than the awful edge these uber cheapo knives came with. Basically I got these things to destroy and learn sharpening, so they are serving their purpose. So I think just with this one video and following the guy's approach, I bumped up the level of my sharpening one notch from where it was. Progress. I'd like to get better though and get the cheap kitchen knives to the point they can shave hair. Then I'll know I've arrived at sharpening nirvana. Look Mom, my kitchen knives can shave arm hair.
So from the discussion above, when I try "round 2" improving my technique some evening this week, I'll stick with the technique in the video that 42 posted, but here's additional stuff I'll pay attention to. Welcome comments on approach here, I'm trying to learn and open to feedback.
1. Reduce pressure
2. Try an increased progression of grits to refine the edge more. Shape: C stone. Apex-and-refine: F, EF, and then strop with my 8000 grit paste.
3. Use arms and shoulders more, keep fingers and wrists locked.
Really if you can't read a blade to see what's wrong with it you're going to just be floundering around way longer than you need to and getting all kinds of frustrated. Edge literacy is the foundation of good sharpening, whether freehand OR guided.![]()
Can somebody please advise me on the scrubbing technique, or point me the best video (whether already linked here, or elsewhere) that could answer this question concisely?
Here's something I realized last night: I'm not having too much problem with doing "slices" on the stones during the sharpening step, but I did have significant challenges with the shaping/scrubbing work on the coarse stones. Why?
So I'm left handed, and when scrubbing the side of the blade where the scrubbing motion is going away from me, that's my "preferred" or comfortable side of the blade. I felt like I had full control, able to keep the angle consistent, and got a fairly nice--what do you call it?--"secondary bevel" on that side. When I flip the blade over to do the other side, obviously I'm scrubbing by pulling it back towards myself. That's where things really go downhill, I'm nowhere near as consistent and I had trouble keeping the angle steady across the whole surface of the blade.
So here's the question: during shaping/scrubbing, when I flip the blade to what (for me) would be the "weak" side where I don't have as good control, is it correct to be scrubbing back towards myself on that side? Or should I try a different approach, like scrubbing away from myself just as I did on the other side, but in this case, I'd have to switch and use my RH as the primary control hand. Basically, I'm trying to figure out the most efficient technique to scrub the "weak" side of the blade and still maintain consistent angles.
That makes sense, I'm gonna try to learn to use my other hand when I flip the blade so that all the scrubbing/shaping work is going AWAY from me.
So carrying this out to its logical end: I assume this also applies to the slicing/sharpening stage. Might as well just change hands whenever you flip the blade so that ALL the sharpening motions are going away from you for consistency, true?
I have exactly same result, where my weaker hand result is flatter and smoother than my dominant hand.That's what I'd suggest. It's what I trained my hands for, for exactly the same reasons. I was noticing obvious differences in held angle and width & uniformity of the bevels and such, when trying to rely only on my dominant hand for control, and trying to change the direction of the stroke with that hand.
Takes some time, but training your non-dominant (weak side) hand to mirror exactly what your strong hand is doing will pay off. In doing so myself, I even discovered my 'finesse' and light touch now seem a tad better with my 'weak' hand, than with my 'strong' hand. My dominant hand is still literally 'stronger' and doesn't fatigue as easily as my other hand. But, I'm finding that my bevels look a bit cleaner, and my finishing touch is lighter with my non-dominant hand now. So, now I'm working to help my 'strong' hand do what my 'weak' hand has learned to do a little better.
David
Maybe you are more aware of what your hands are doing since you are trying to be extra careful.You guys are right on that point, it was weird, I got a more consistent and cosmetically nicer looking edge on the side that I used my non-dominant hand for. What the heck is up with that?![]()
It is a good thing to realize that you have that control readily available. Now you just have to control it evenly with unevenly distributed muscle mass and dexterity.
