- Nov 9, 2004
sounds like real elite stuff, cant wait to get one. thanks for breaking it down, this stuff is going to kick ass!
America has reached 250 years, and I am grateful to be here, in the best country in the world. Thank every one of you who helps make this country a better place, those who have gone before and risked it all, and those who've paid the ultimate price to make the United States what we are today.
Broos I think your correct. How ironic is this statement and thread coming from Cliff who refuses to post his CV or even a list of his self reported dozen or so peer reviewed published papers?Quote:
Originally Posted by Broos
... this thread is a good illustration why most mfg's do not release this kind of info.
Nonsense, the ones who are confident in their results release the information like Glesser. All such analysis is SUPPOSED to be subject to critical analysis.
Science doesn't proceed on faith and blind worship.
-Cliff
[...] this is an example of really misleading and biased statistical analysis. [...]
-Cliff
If the claim is that the FF process is superior than a direct comparison should have been made with a same hardness standard process D2 blade.
Sputnick what personal information would that be?Regardless of cliffs desire to provide personal information that db has so courteously reminded us all of,
With accusatory threads like this and posts like yours how likely do you think they will be forth coming with additional info?Data is data. Testing procedures are relevant. How someone interprets those things can and is often misleading/biased. In this particular case there are
too many variables to simply make the claims they have or to transpose their findings into the likely actual use of the blade.
I don't know how likely it is that we could get our hands on the actual data points they got from testing. That would make coming up with unbiased conclusions too easy for us and since promotion is the goal, why would they want to do that...
The edge retention test seems to show that with identical geometry, finish, and ultimate edge width (verhoeven seemed to call this bur width) that the structure of the FFD2 is a significantly more aggressive slicer (at the start). Sorry but I can't swallow that one.
Cliff, point me to similar testing done by Spyderco for ZDP-189. Especially similar cutting tests vs. other steels. I have not run across this yet.
I think using the exact same edge geometry and exact same sharpening procedure for each blade is the correct baseline to use to start this test. As the test methodology section explains, the REST tests were done before, during, and after the cutting testing.
The biggest problem is number of data points.
The amount of material per cut is greater for the FF blade thoughout the test. This test may not be a test of pure edge retention, but it does show that the D2FF blade, in this test, will outcut the other steels throughout the test, out to hundreds of cuts (with the same edge geometry and with the detailed sharpening done).
You have not looked very hard then. I have referenced such work many times on the webpage on steels.
-Cliff
As stated at least twice, the REST values were the same at the beginning of the test. REST = sharpness.
And what specifically about their sharpening method favors D2FF, Cliff.
You guys are stating that the blades were not the same sharpness at the beginning of the test ...
And after looking for 10 minutes I don't see any links on your site linking to Spyderco's steel/knife testing results.
In all those years I never had a knife go over 80 cuts. The first Friction Forged® blade I tested went 300 cuts.
That is a fairly strong testament to thier performance. Have you used S90V at 60/61 HRC?
The primary carbides in friction forged D2 are just chroimum so I would not expect any difficulty in grinding. With the high hardness I would expect that it should be easy to get a crisp edge and that combined with a suitable very thin edge should make them easy to sharpen.
I would be interested in how they would compare to CPM S90V and 10V when Wilson does his rope testing.
-Cliff
