I'd recommend buying the things separately and assembling your own.
I keep several in my truck and I noticed some have lots of wasted space with things you don't use much, and you run out of certain things. And I've 4 different name brands/types Not one is "perfect".
For example, I don't need 10 regular band aids and 10 micro band aids, the micros take up space, but are barely useful. (Thats just an example). (Got them all for free btw)
My advice. Shop online and look at what comes in first aid kits, then try to find everything separately. (But thats just if you like building your own kits/customizing things)
Gauze, high quality band aids, the tape used on top of gauze, and antiseptic/triple antibiotic ointment are my most used items. I've found the majority of my injuries are cuts/scrapes. (I'm a skateboarder so I use all of my first aid kits quite regularly).
I can promise you, a well cleaned cut with proper attention heals much better then an uncleaned, unattended to wound. I keep first aid kits in my pack, truck, room, ect.
PS: I'm thinking of adding a large syringe (not with a needle), so I can fill it with water/alcohol/peroxide and use the pressure of squirting it across the wound to clean out any dirt/particles. Its a bit painful, but it cleans an open wound nicely.
ICEAGE
Registered User Join Date: Apr 2007
I'd recommend buying the things separately and assembling your own. Or, buying an already assembled and modifying it to suit your needs.
