I just got a tube of Frog Lube, and all I can say is that when used correctly, it REALLY is amazing.
The key is to use it correctly. Warm up the metal, put on the Frog Lube and let it sit for an hour or so, and then wipe off the excess. THAT is the key... wiping off the excess. The test one fellow did on 46 different products for rust prevention proved Frog Lube's worth, enough for me to switch from my favored 'Marine Tuf-cloth,' and now the tests that he did for lubrication shows it to be just about the best on the market for that too!
Adding more lubricant creates more surface tension rather than more lubricity, and increases the energy needed to overcome 'sticktion.' The Frog Lube creates more than enough slip without having a visible surface layer that we've come to associate with lubes. My EDC has never been so smooth.
The key to making it work correctly is to use it correctly. What a concept! LOL!
Stitchawl
Stitchawl
