- Sep 22, 2003
I usually don't sharpen my convex edges with the blade flat. I usually use a mousepad or adjustable tension strop and have a slight angle. The sandpaper follows the convex shape without scratching up the blade.
thombrogan said:Take the knife in need of sharpening and lay it flat or nearly flat on the hone. Move the knife in small semi-circles over the hone until a burr pops up (assuming you have a knife with steel that easily burrs - that should be 98-300% of your collection). Flip over and repeat. Do a few light, alternating passes over the hone at a slightly higher angle to remove the burr.
Abe said:Does this mean the semi circles are made completely in the horizontal plane ie with the blade always flat to the stone, or that they are in a vertical plane ie described by the spine lifting up from the stone in an arc in a straight stropping-like motion?
A 15 degree edge for example is easily strong enough on even a decent steel to chop up caribou legs with no visible damage, this is obviously way overkill for a utility knife made to cut things.
sodak said:Could you describe the circles to me? I'm having a hard time understanding why this would produce a convex edge. It seems to me that it would give a real nice thin v-grind.
sodak said:I'm having a hard time understanding why this would produce a convex edge.
kel_aa said:Try to tell them about the 850% performance increase in slicing cardboard while they are choking your eyeballs out.
Does this apply to decent stainless steels too?
I recently deboned 4 chicken quarters and cut up the meat on a plastic tray, and the edge was reflecting light at many places.
I have the hardest time sharpening the ATS-34 in the AFCK. I feel the grain is coarser than many others. I can end up with a functional edge, but I get reflective spots where I feel I should not sooner than I expect. I really do notice how much more abrasion resistant it is from sharpening it. I also get the impression that it is fairly ductile (opposed to crisp. I guess by crisp, I mean no burr/wire edge or movement of the steel at the edge). Any ideas?
Abe said:So by way of illustration, if I was to try this with, say a flat ground kitchen knife with a 15 degree secondary bevel, I would place the blade flat on it's primary grind and hone away in flat semi circles until the secondary bevel disappears and a slightly convexed full grind (spine to edge) was left? Quite a bit more time required than the original post suggests, then.
Is the Fikes video somewhere on this forum?
db said:The type of stroke you use doesn't really matter ...
As for the finish and scratching the side of the blade, who says you have to stop at the coarse hone?
db said:There are many different ways to sharpen. No one method is right for every knife or every knife user. I do the convex on a bench hone because it works for me and I don't really care about resale. It's the easiest way for me to thin the blade grind on factory knives I think they are ground too thick in most cases. I don't really understand the scratched finish part. After I'm done sharpening I've put a really nice finish on the knife that I can reproduce easily after I've scratched it from use.
They would not hesitate for example to take pretty much any knife for any cutting if it was the closest thing at hand and would readily take and AFCK and cut/scrape putty/gum off of concrete.
kel_aa said:This is assuming you handed them one, because they would never buy one in the first place?
But once they spend the money to get a "nicer" knife and get to know the "story", I think they would start appreciating it too.
But on the other hand, arn't you buying what the designer/maker's idea of a knife?
