Yes, the SM is sufficient for such steels ... within reason. I use it on ZDP189, S35V and S110V.Considering just getting the sharpmaker to start. I have just heard the diamond rods aren't the best and if I were to have to reprofile it would still take a long time. I do prefer a standard 20 degree though which the sp does. Is the sharpmaker sufficient for steels such as s35v and m390?
The diamond rods are good. The CBN rods are considered 'better' only because an improved manufacturing process enables the CBN particles to adhere to the metal substrate better.
Both the diamond and CBN rods are 400 grit. And this is where the issue is for serious repair/reprofile work. Even on my DMT system, I find the Coarse 325grit stones inadequate for such work and prefer the X-Coarse 220grit and even the XX-Coarse 120grit stones.
I used my CBN rods to reprofile a Delica in ZDP that had uneven bevels. It took awhile at 400grit but it worked.
Which is why I ordered the 250grit Eze-Lap Diamond Files.
It's also why the Atoma 140 stone is so popular.
I don't mind if it take a long while, as long as it is possible. And that it makes a pretty edge that is sharp. Thanks for the super informative replys everyone.
In my experience the time it took was the problem, it's a slow process. I wasn't seeing results fast enough so I'd lose focus & get bored or try to rush which all resulted in sloppy work. I could get a knife very sharp with it, but the time it took to get there or see results was to long for me personally. I still use the sharpmaker rods often but I use them freehand to touch up edges.
Wise words.
I have lots of sharpening equipment. By FAR my most used tools are the SM, a couple stones, a glass smooth steel from handamerican, and strops. I only use the edge pro if the edge needs a completely different angle, or is heavily damaged.
Being a beginner, I'd highly recommend a sharp maker for you, or simply learning to freehand.
If you're set on the edge pro, go for it man. But I'll tell you this - it's a PITA to set up, dial in, and use. My left hand doesn't want to do what my right hand does easily. If you get one, you'll see what I mean instantly.
L
How often do you come across edges that need different angles or heavily damaged? And I am quite curious what you mean by your last comment haha
Yes.Travis when you say dmt stones do you mean to lay on the sharpmaker like you post earlier? Or does dmt actually make a type of system?
