+1 on that oneHarbor Freight sell transfer punches. I sometimes double sticky back tape both pieces to each other. This is before shaping the new scales. Transfer the holes from one to the other and then mark the outline when screwed to the knife. Remove and shape the scale to the knife or original scales. I always put in the holes prior to shaping the scales. This works for me.
Ron
I don't see anything wrong with that. I like it. Good work.
Cool pattern on the G10.
I think those are pretty freakin sweet!
Ron
+1 on that one
A drill press is best.
Double sided tape is awesome, it will allow you to drill all the holes on both scales at once.
First, the pivot hole.
Second, the hole furthest away from pivot.
Then all the ones in between.
(I drill the countersinks before drilling the though holes)
Have fun!
BM screw heads/countersinks are .050"
The pivot countersink could be .055" or .060" I can't remember which (.055" I think).
Of coarse if you are using the original screws and the new scale material is thicker than the original scales; then the countersink will need to be equally deeper (math involved).
For example:
Original scale thickness .100"; Original countersink .050"
New scale thickness .110"; New countersink .060"
Be careful not to over countersink.
It's easier to take more off, than it is to put more back on.![]()
It might be late advice, but I know with woodwork I like to save some sawdust to mix with glue to fill voids. You might be able to mix the g10 powder with epoxy and fill the hole so it cant be seen. But Ive never tried it with synthetics before.
In case you are looking for the right tool, you only want a countersink for flat head screws. They come in 82 and 90 degrees. Most screws are 82*. Counterbores are for flat bottom holes and for round head or cap screws. I make my own by using a drill bit and making it with a flat bottom on a grinder. Much cheaper this way. You start with the proper size drill just to break the surface and then go with the flat bottom bit ( counterbore ) to the depth you want for the screw head. You should use a drill press and have everything held securely or the drill can pull into the material if not sharpened properly. This happens in non ferrous material. They do sell counterbores for different screw sizes. Best of luck.
Ron
rpttrsn is right about the terminology (countersink/counterbore).
In your case (for BM screws) a counterbore is needed.
You will find that "countersinking" has become a general use word used to represent the act of recessing of a screw head into your subject material.
When searching for these drills you will find that wood working retailers will refer to them as counterbores, as rpttrsn has already stated.
However, online knifemakers supply stores normally call these items "step drills" and they are available in many different sizes.
Here is a link to ones sold by knife kits:
http://www.knifekits.com/vcom/product_info.php?products_id=530&cPath=49_193_206
This site is awesome, I don't know exactly how much trial and error you guys just saved me from but, with the tips within the few posts we've shared,
I have already worked out a completely different approach to this project... although the budget grew a littleso did my admiration for the customization work you guys do around here!
Thanks Again.
Sweet!
You've gotta be happy with that.
Lookin' good.
I will pipe up and say that I would happily put your knife scales into my pocket on a knife.
Keep up the good work.
