The Garmin Dash Cam Mini is as small as a car key, it features a 140-degree wide-angle lens that captures 1920 × 1080 resolution video at up to 30fps. Once plugged into your vehicle's power source, it continuously records and automatically saves video of incidents. The built-in WiFi connectivity enables the camera to upload saved footage to your iOS or Android device via the Garmin Drive APP. If you use more than one Garmin dash cam to capture the surroundings of your vehicle, the Garmin Drive APP automatically combines and organizes the media files from multiple dash cams for easy viewing and sharing.
Product Features:
● As small as a car key, allows mounting behind rearview mirrors, and goes virtually unnoticed.
● 140-degree wide-angle lens, can capture 1080P HD quality images.
● Automatically records and saves the video when the integrated G-sensor detects a collision.
● Easy to connect, import saved videos into the Garmin Drive APP via built-in Bluetooth and WiFi.
● Garmin Drive APP for easy viewing, editing and sharing images.
● Dash Cam Auto Sync enables you to control and play back footage from up to four cameras on your smartphone using the Garmin Drive APP.
● If you use multiple dash cams to capture the surroundings of your vehicle, you can use the Dash Cam Auto Sync feature to set up your network and and keep the devices in sync recording.
● The parking mode monitors the car's surroundings when your car is parked and the engine is not running. When the vehicle is shaken, automatically save the image.
● Onboard card slot supports microSD/SDHC/SDXC cards 8GB or higher.
● The included dual USB car charger can charge your phone or other accessories while powering the device.
Garmin Dash Cam Mini keeps a constant eye on the road to make your journey even safer. With the ultra-compact dash camera, you'll have a discrete eyewitness on the road: https://gearvita.com/garmin-dash-cam-mini-car-dvr-camera.html
Related products:
xiaomi 70mai 1s dash cam
70mai dash cam pro
Product Features:
Related products:
70mai dash cam pro
