Any news back on this one OP?
It is on the way back via UPS.
Says Tuesday delivery.
I will up date then
I wonder if the detent ball in the GB2 is exactly the same as the one used in the GB2 ? I recently got the GB2 and I'm impressed.Could be, or could be anecdotal - I've seen some GB1's that have been to hell and back.
I'll be looking forward to your update as well. Best of luckIt is on the way back via UPS.
I will up date then
Pretty sure Spyderco, or any other knife manufacturer for that matter, doesn't make ball bearings. That is a sourced item, and defective ones cannot be completely ruled out. That is why I prefer ceramic - no way a bad heat treat occurs in those.I wonder if the detent ball in the GB2 is exactly the same as the one used in the GB2 ? I recently got the GB2 and I'm impressed.
Having a dependable source for quality heat treated hardware is a huge deal.Pretty sure Spyderco, or any other knife manufacturer for that matter, doesn't make ball bearings. That is a sourced item, and defective ones cannot be completely ruled out. That is why I prefer ceramic - no way a bad heat treat occurs in those.
is this a common thing? never had a problem with detents failing......is it rare or commom, thanks y'all.
Ceramic is harder than steel.
So instead of scoring a bearing you get the nightmare scenario of grinding the damage into the blade itself.
Having the ball fail like a fuse in a panel sure seems like a better outcome to me.
That is an excellent point (corrosion elimination) that I hadn't ever considered.Hey Danke, that shouldn't be a problem. The surface area on the tang is vastly larger than the surface area of the detent ball so any wear should be minimal compared to the wear you see when the ball is softer than the steel. Even if it forms a visible groove it won't hurt anything. I haven't worn a detent ball down but I've had one wear from corrosion in saltwater (Spydiechef). I think ceramic balls would provide both better wear resistance and corrosion resistance.
