a survival mindset is nothing that you can cram into a kit, but is often the difference in making it and not
I do think whenever you put together kit, from tiny to large- you must have the priorities for your environ (these can certainly change around the globe) deeply entrenched in your mind (rules of 3 come to mind)- where I roam preventing exposure is the number one priority- even in the middle of summer, so shelter raises to the top- this includes suitable clothing (worn and packed) and also includes fire- the ability to start a fire may be the difference of making home or not, so it's a no holds barred endeavor- lighter, storm matches, manmade tinder, acetylene torch!- whatever it takes
small saw is one of those items (unless you have room for a big saw
) that should be in all but the very smallest kits; paracord (or for small kits- smaller cord)- a little is good, more is better
water is a secondary concern, but still plenty important- regardless of season- if I can purify water all the better (micropur tabs are effective, small and light should be in every kit regardless), but if push comes to shove (hope it never does!)- I'll worry about the effects of bad water at a later time
-a small section of aquarium tubing can get you into little crack/crevices that you might not normally can get to
signaling is often overlooked, but seeking actively help is probably the most likely scenario we'll find ourselves (dodging zombies probably less so
)- a whistle and signal mirror take up very little space (and weight)- of course fire, emergency blanket, flashlight, etc can
not downgrading first aid by any means, but with a wilderness first aid class under your belt you find that many good "fixes" are ones that you can improvise from carried and found items, still carry a well thought out kit
navigation- you may be forced to get on your volition, a small compass can go a long way in that regard (as can a analog watch in a pinch), a proper map and compass being ideal; a good working light if space permits gives you precious hours into the dark
food while certainly a lower priority, it can certainly positively impact getting out of a bad situation- low bulk, high calorie if there is room
a good sturdy knife is a given on this forum isn't it
