- Aug 24, 2010
you an easily lower the blade by filing a minute amount of steel off the kick.
true, but filing the kick also lowers the backspring, which is NOT cool:
Your options if you receive a knife that does not meet your expectations for fit and finish, is to return for refund, or replacement. You can also send it to GEC for repair.
I googled knife parts description for you
http://www.allaboutpocketknives.com/research/knife_definitions.php
also, here are photos of my modified (left) and unmodified (right) Sheepfoot Charlow kicks
and the resulting back spring drop when closed (the modified one on the bottom). Changing the kick does not affect the spring position at half stop, nor at full open. fwiw, both my sheepfoot charlows have proud backsprings in half stop. The single bladed one is flush when full open. The two bladed one has the spring just barely below the liner, enough to catch a finger nail, when fully open. I currently have 5 GECs on the #15 frame. None of them have flush springs in the half stop position, not even the one that I sent to GEC for repair of a wobbly blade, that I caused by opening and closing the knife too many times while watching TV. In fact, 3 out of 5 of my 15's have wobbly blades from the same "break in" behavior of mine. I have not been willing to send them back to GEC for repair, nor do I have experience hammering my own pivot pins to tighten them up.
and here is the result of filing the kick, on the knife on the left. The blade now sits about 3/16" lower at the tip
