The days of honor of us knife people takes a hit. Good thing my integrity is still intact that I won’t pass it off to anotherMaybe thats why it was sold to you.
If you're going to throw it away, I'll dispose of it for you.The days of honor of us knife people takes a hit. Good thing my integrity is still intact that I won’t pass it off to another
Much appreciatedIf you're going to throw it away, I'll dispose of it for you.
Good advice. I’ll work at it a bit more and learn to appreciateThe spring holds the blade open and closed. The knife is functional. Carry it. Use it. Fiddle with it. Work it over and over. Time will pass regardless, you my as well break it in real well. My guess is that it will resolve with use. Flushing it 2 times is not much of a go at it.
Yea I can’t figure it out. Weak close and stops but can be pushed down. I got some air and will try to flush it with oil and air this evening. See if that shakes something loose. Doesn’t feel like a blockage just a defect in the mechanism. The pen blade is much tighter while the main blade feels soft but locks up fine. A fine conundrumThe only knife I've had that behaved that way was rubbing the liner slightly. I assume you've checked all that on yours, though.
It's a mechanical device... if it can physically go all the way "home" when nudged, then that means it's capable of it. So, there must be something slowing it down/stopping it at the last moment of travel..... either blade rub, or some trash in the joint.
If it was a factory defect, I don't think it would push down into place so easily, and remain there.
I suppose it could be a rough spot on the side of the blade in the pivot area, but that would be the last thing I'd check/suspect.
Interesting issue.... frustrating, but interesting....
I had a knife for 2 years that I always thought was just a bad knife. One day I opened it felt a little pop and a sliver of brass pops out. Now it's about as smooth as can be.The spring holds the blade open and closed. The knife is functional. Carry it. Use it. Fiddle with it. Work it over and over. Time will pass regardless, you my as well break it in real well. My guess is that it will resolve with use. Flushing it 2 times is not much of a go at it.
InterestingI had a knife for 2 years that I always thought was just a bad knife. One day I opened it felt a little pop and a sliver of brass pops out. Now it's about as smooth as can be.
I’m not but if can’t deal or fix it and GEC won’t take it back i would love a contact to send it toif you are really handy, you can even take it a part! some folks make it a pretty good side hustle, one guy i know of even went on to become a custom maker
Thank youone of my go to guys is @jsdistin , i wonder how his schedule is these days...
Sounds like I should have bought a different number.If I keep my Pony oiled the action is okay. When I take it out of storage it is iffy untilI I re-oil. Best of luck.
