- Apr 12, 2009
Don't need much over-rotation at all, to make the central portion of the blade contact the raised 'hump' of the backspring. There's often barely more than a mm of space in between, at THAT point, with the blade at rest in the closed position. Even with a very tall kick on a blade, which keeps the BACK (heel) of the blade far away from the spring, the central portion, belly and tip of the blade are very often MUCH closer to the backspring/spacer.
Think of a lever, hinged at one end. Even a tiny bit of motion at the hinged (pivoted) end will produce a much larger deflection further away from the pivot. Most of the knives I have, with this problem, have the problem towards the far end of the blade, usually near the upsweep in the belly, where the end of the handle and spacer are also upswept. A handful of my knives also have the collision point at the 'hump' in the backspring. That 'hump', in itself, can be a major contributor to the problem, if it's just a little too tall.
