black mamba
- Oct 21, 2009
The four inch, large stockman has been, for some time now, my favorite pattern of pocket knife. GEC’s #81 pattern has met with such rousing acclaim (with prices going through the roof!) that I decided to do a comparo between it and the knife which most likely spawned it, the Schrade 881. To compare apples to apples, so to speak, I chose a green bone version of each knife. The Schrade is a Parker-Frost branded knife from 1978, while the Tidioute is from 2013, and both have 1095 carbon blades.
You can see that the Tidioute is a slightly larger knife, both longer and deeper, although it is actually thinner through the pins. The springs are slightly softer on the Schrade Parker-Frost, about a 5 to a firm 6 for the Tidioute, but both have good snap. The one drawback to the GEC for me (otherwise I would probably have every handle option
) are the short bolsters. Not only are the bolsters shorter on the #81, but because it is also wider, they look even shorter. I think they make the knife look a little “blocky.” But both are beautifully made, and about as useful as a pocket knife can be.
Let’s see your photos of either of these patterns, and tell us what you like and dislike (if anything) about them.
