AusLoX
Platinum Member
- Jan 23, 2015
Spyderco just sent out their monthly "Byte" for July. They had some info on this topic.
Hope this helps
"Edge geometry begins with the grind, thickness, and width of the blade and its bevels. For example, a full-flat-ground blade basically has a triangular cross section, with the spine of the blade being the base of the triangle and the two equal-length flat bevels forming the sides. If the planes of the bevels intersected perfectly at the edge (a zero-ground edge) it would be extremely acute and sharp, but very weak. Narrower blades, thicker blades, and shorter bevels would all affect the geometry of the triangle and increase the angle at the edge somewhat, but it would still be somewhat weak.
To give the edge greater strength and make the blade easier to produce, the bevels typically dont converge completely. Instead, they leave a thicker section of steel near the edge. A narrow secondary bevel is then ground at a steeper angle to create the actual cutting edge. The terminal thickness of the steel adjacent to the cutting edge is also a determining factor in the overall edge geometry of the blade.
A full-flat grind with a thin terminal edge thickness creates a very acute angle near the edge and the long, gradual rise of the bevels. This geometry parts the material being cut with minimal friction and offers excellent cutting performance. It also produces a distal taper that reduces the weight of the blade, but also decreases its strength.
If strength is a concern, a partial flat grindalso known as a saber grindcan be used. With this grind, the flat bevels are shorter and the angle near the edge is slightly steeper. This puts more steel behind the edge, but also forces the secondary bevel of the actual cutting edge to a larger angle as well. This geometry parts material more abruptly and creates greater friction during the cut.
In many ways, a hollow grind offers the best of both worlds. Since its bevels are actually concave, it can produce a very thin terminal edge thickness and support an acute cutting edge angle, while still maintaining a thick spine for strength. Hollow-ground blades can also be sharpened many times before the edge wears into the thicker part of the steel. Flat-ground and saber-ground blades reach that point sooner and ultimately must be sharpened at a more obtuse angle."
Hope this helps
