- Mar 7, 2001
Lagrangian,
I just realized in these system, 90 dps is not catered for:foot:
@brplatz:
Oh, i forgot to mention that for a tanto knife, the WEPS will sharpen the long edge as a perfect dihedral (in theory). And if you upgrade the WEPS with the Pro-Pack II so that it uses spherical joints, then it can sharpen both the main edge and the tip as a perfect dihedral (in theory). Details about this can be found in the chapter about the WEPS and also the chapter on optimal pivot placement.
The EP can sharpen a perfect dihedral angle, if you are sharpening at 30 degrees per side on the Edge Pro Apex, and 15 degrees per side for the Edge Pro Professional. Details about this are in the chapter about the Edge Pro Apex.
The chapter about the Edge Pro Apex also talks about modifications to the designs that would make them perfect in theory.
I am also trying to think about how a flat stone would effectively sharpen a recurve blade such as my ZT0350. I am assuming that even at the 30 degrees per side of a EPA, two points of the stone are touching on the convex portion, then one point when it bends around to the "normal" portion.
Brian
Even if so, not a problem. Look at the triangular "stones" of the Spydie Sharpmaker.
Thank you for your under estimated amount of patience. I tried doing this for my kinematics class years ago and lost it
@brplatz:
Hmm... I haven't thought too much about recurves. However, it seems that WickedEdge has. I don't know the details, but they sell some sharpening stones for the WEPS that are convex and specifically designed for sharpening recurves. At least I think they do. From what I remember, they do the right thing, where the sharpening stone surface is a cylinder with axis centered and aligned with the guide rod axis, and the radius is the distance from the axis to the stone surface. So in effect, you would be sharpening with a big cylindrical stone which is aligned with the guide rod. Because it is effectively a cylinder, any "twist" along the cylinder axis doesn't make a difference in sharpening angle.
I suppose if you had a rectangular sharpening stone, it would work OK too, so long as the 90-degree edges were well rounded off, and in general you had a two-point contact with the knife edge (ie: two rounded edges in contact with the recurve) so that the orientation of the stone is completely determined. The cylinder idea from Wicked Edge is interesting, because the "twist" part of the orientation doesn't matter; turning a cylinder along its axis doesn't change anything. But for a rectangular stone, it matters: Sharpening on the "flat" of the stone can produce a different angle than sharpening where one is sharpening only with the rounded edge on one side (like, you do a 45 degree twist along the guide rod).
Sorry, I'm not explaining this very well. If you're confused, let me know, and I'll see if I can make a diagram for it.
From the math, I don't think it is possible for the EP or WEPS to sharpen a recurve at a constant dihedral angle. In the chapter on optimal pivot placement, the only knife shapes that can be sharpened at a constant angle are ones with a straight segment followed by a circular arc, and then followed by a straight segment again. The spherical joint of the WEPS would have be located so that its perpendicular projection lands on the center of the circle for the arc. In the chapter, I try to explain that there are no other possible shapes, only a circular arc with straight segments on each side of the arc. (If the straight sides are zero length, then the arc could can be extended into a full circular blade.) I'm probably explaining this poorly here too. I think I did a better job in the report, so maybe have a look at that. If that is confusing, then ask me again, and we can sort it out.
Whoa.... When you say "my kinematics class" do you mean a class you attended, or a class you taught?
but on a recurve that center location is on the wrong side. On a recurve it seems to me that the pivot point would have to follow a concentric angle to the curve of the recurve to be constantly dihedral.
I hope that makes some sort of sense, perhaps I'll draw a diagram.
Regardless of the magnitude of change (or lack thereof) I find it interesting and fun to come up with theoretical perfect situations for stuff like this.
Poor wording on my part. The kinematics class i attended would be more accurate. Used to talking to other students about "their" classes. The way you did it sounds much easier than on paper, but that's only comparatively. Not saying it was easy at all.
