- Feb 2, 2011
I took a photo, but I dont know how to attach it!!!
I got one of the "Mark II" versions of the BG Ultimate knife from RockyNational. From the outside I noticed the following differences. On the back of the blade, the cleared portion for using with the fire starter is ground 2 1/2 x longer. The pommel is a different shape where it joins the handle, with a wider orange bit and the pin appears to be about 3 cm in from the end.
Those cheap ones with the bottle openers and saw back from the 1980s were better.
OK, even I can't believe I did, but I bought the large folder in this series.
I admit, when I first saw a picture online, I liked the design, even with the BG stuff on it, but wasn't gonna buy one unless I could hold it first.
My local Dick's Sporting Goods got them in, and even cut one out of the packaging so I check it out.
Out of the package, the blade is actually "arm shaving" sharp, both the plain and serrated sections.
Lockup is solid, no play in any direction.
Handle is all synthetic, the orange is a hard plastic and the gray is non-slip rubber. No liners inside, so I'd be REAL reluctant to baton this thing! Ergonomics are great, they actually did a good job there. (adding steel liners, even if it added weight, would be one thing I'd change.)
Sheath is typical Gerber, fairly thick nylon, with a Velcro closure (another thing I would change on an outdoors knife, I want a strong metal snap), carries vertical & horizontal, and in my experience, lasts about 2-3 years before you have to buy a new sheath.
Will try to get out and bang it around a little and see how it performs...to some degree, it is what it is, and keep within sane usage and not to extreme, I can see it being a decent camp knife for the price.
The Gerber metolius is actually a decent knife
Buy him a Buck Vanguard and get over it.
