Lower bore axis increases the
ability to control recoil, not simply provide a "feeling"; a polymer frame helps as well.
The ability to control recoil and felt recoil are the same thing. The lower the bore is in relation to my hand, the less I'm going to have to fight against muzzle flip. Thus I'm going to percieve that the pistol has a less amount of recoil.
But as I said before, bore axis is only one factor in regards to recoil.
Caliber is the other primary factor(9mm has faster recovery than .45 or .40)
If you're talking about fast as in rounds per minute, that has little to do with caliber and lots to do with the platform. Glocks, sigs, 1911s and others will all shoot faster than is humanly possible to pull the trigger anyways so thats a moot point. If you are talking about fast as in how quick it takes to get the muzzle on the target, then I disagree as well. For as long as these two calibers have been around, 9mm has been described as "flippy" where as .45 has been described as a "push". As a result, recovery is going to be, if anything, a matter of preference depending on the particular shooter.
You shooting GM, brother? No, I don't either, but that is one of the most flagrantly ignorant statements I've heard.
Glock's polymer frame mitigates (not enhances) recoil transmitted to the shooter. Not "felt" recoil, transmitted recoil (ie, "measurable").
Sorry, but as I said before physics dont change because gastons name is on the pistol. Yes a lower bore axis will mitigate felt recoil. Yes a polymer frame flexes and accepts some of the energy from the round fired. Weight, however, is still an issue. The lighter something is, the more its going to move when subjected to a constant force.
A glock 17 weighs in at 625 grams unloaded. A sig 226 weighs in at 870 grams unloaded. The sig is nearly 40% heavier than the glock. Since the energy expended by both pistols is exactly the same, the shooter is going to experience 40% less recoil with the sig. Now if we take into account bore axis and the frame flex of the glock, that 40% shrinks.
However even if we are overly generous and say that it will completely mitigate the weight differential, which is highly doubtful, we are still left with a draw.
This, of course, is what I said at the very start. Every pistol has its advantages and disadvantages. So someone that opines that the glock is better because of a lower bore axis, or that bore axis is the end all be all of pistol ratings is either being ignorant or dishonest. There are many factors that go into whether a pistol is great or not, and these factors change in priority from person to person.
Simply put, any statement that says the (insert pistol here) is the best combat/defensive pistol out there, is hogwash. The best defensive pistol is the one that works best for you. And as much as some people hate to hear it, there are lots of people that find that glocks don't work best for them.
