First of all, thanks for taking a look. I also want to say that this is more of a hobby for me that sometimes gives me a little extra cash.
The rail road spike knives are more for show and fun anyways.
I do want to correct a few mistakes you made. On my axes, and I've only made two, nothing is welded. Everything is pinned. The bits are held by three 3/8 inch steel pins. I beveled the holes to ensure a tight fit. Another point you made was the squared ends on the bar stock. Only on the throwing ax are the ends square, and thats because I only use it for throwing and since that was my first ax using pins, I wasn't even sure that would work, but it appears it does. I don't chop or split with it. On the camp ax, I did bevel the ends. Splits wood just fine. That ax I had no trouble testing. Spliting 6 inch logs isn't hard with it, and choping isn't bad either. My axe handles could use some work, I'll admit, but I only just recently managed to make some that are durable. Those are the first handles I made that didn't break after only minor use. But to be honest, I like the look. And to be honest, I used a bandsaw, bench grinder and disk sander to shape them.
