The Garmin 60cx has fast become the GPS of choice in my profession, replacing the 12, II and III as being a "professional grade" full feature GPS at a reasonable price. I'm a daily user, and I've tried most of them out there, from the $80 eTrek to the $80,000 Trimble. The Garmin in my opinion is the best one out there for the money.
In my opinion, the only real difference/innovation that matters these days between GPS units currently on the market, is the antenna... you can get a higher signal to noise ratio from a high sensitivity/high gain antenna, thus more signal in tree cover.
Just remember.... when your standard off-the-shelf single frequency GPS spits out an error number in metres or feet, depending on the GPS, this may just be an estimate or a relative error based on the last few readings, or a "best case" error estimate based on current satellite geometry. The thicker the foliage, the more multipathing and signal degradation and the higher the absolute error, a high PDOP (>=4) and low satellites (<=5) means higher error, these two numbers are much more important in judging the true quality of your GPS position than your error value
As good as GPS is, it will never be a subsitute for pace and compass navigation.
