As others have said, your soak time was too long for 1084 and MUCH more importantly your temp was too high. Grain growth is much more dependent on temp that time. For a forge HT never try to do your normalization cycles or hardening process in an already forging-hot forge. Either turn it WAY down and wait a while for it to cool, or better yet, start that process while the forge is slowly warming up with a feather-flame. I break tips to check grain size on my forge-HT'd blades to get a good look as that's where overheating typically occurs. The number of normalization cycles necessary for good fine grain size is highly dependent upon the grain size you're starting with prior to the cycles. Because you're not forging the grain size should have been quite small in the mill-stock and only grew from too heavy/hot normalizing and soaking. A normalization or two just above or even a little below critical (you don't HAVE to soak that long for that steel to reduce stress, recrystalize and normalize- and anyway, what's worse a little more chance of warp (correctable) or bad grain size/increased brittleness/inability to take a fine edge?) is much better as the grinder is NOT going to put in massive stresses like forging does unless you're REALLY getting it hotter than you can hold, so the need for a heat soak normalization is less and if you keep the temp low (at or below bright red) then your grain size will never get out of control. Also, I suggest heating for the quench slowly (starting forge like I suggested earlier) and watching the steel slowly go through the red heats, moving the blade to keep heating even. You will notice parts of the blade turning a brighter color- bright-red/orange while some interior parts stay darker red- the blade is transforming phases before your eyes (shadowy transformation stage) as that transformation soaks up a lot of energy (energy of transformation). For 1084 when the blade all becomes the same color out of that transformation, quench. If the forge is too hot and you're heating too fast the core will take a while to transform while the edge overheats, so keep your temps as low as possible in the forge for control- this is the absolute key.
Mess around with it, break some pieces, that's really the only way you're going to figure it out for your forge and your setup. I've corrected overheated 1095 blades with grain size almost as bad as the ones you showed (even the tang pic had too big grain size btw) by 3 critical/subcritical heating/cooling cycles- but you HAVE to check and look-as there's no magic number, only results. Good luck!
~Luke
