Great Eastern open house
Those sound like great ideas! The Peanut would be an instant hit, I think.
Can you imagine all of the bites from those peanuts with about a 7 or 8 pull? I'll take missing a few fingertips to get a peanut from GEC though! I really like those Missouri knives, are they Gathering exclusives, or available for sale?
I agree, that walnut is beautiful! I bet it looks even better in person. Here's a link that pertinux posted in another thread. It says that they only make a certain number of those knives just for the rendezvous and a few are available for sale each day. Apparently people have started lining up early to have a shot at getting one.
I'll sign that petition Johnny! I'd love to see all three from GEC, and would probably buy more than one of each in different handle materials/colors, something I don't usually do :thumbup:
I've never been but I'd like to go some time. I might try to drive over next year. For those in attendance, have a great time.
Ben
I had a phenomenal time at GEC yesterday. Bill Howard himself gentled the spring on my 25 Jack's secondary blade (although I didn't realize who "Bill" was until after he'd walked away with my knife). He later explained exactly what he'd done, and why he didn't recommend that he try to loosen the tiny coping blade on my new 26, and what to try instead.
I had no idea how much individual work went into each finished knife (as in: all of it. Every step. One at a time). Because I arrived during a morning lull, Pat Vroman gave me a personal guided tour. One highlight was having an older gentleman (who evidently trained Bill Howard 30+ years ago, at Queen) show me the results after each step of his grinding/polishing/buffing of a barehead stag knife.
Sorry, no pictures of the tour; because it was just me one-on-one with Mr. Vroman and then with different workers in turn, I decided to soak it all in instead of trying to take pictures. Hopefully someone with a better camera (and Skillz) will step up.
I loved the zero-pretense atmosphere of the factory and its workers. I already knew I loved the knives, but gaining a new understanding of (and respect for) the people and the process makes the knives all the more special to me.
~ P.
I think, this whole Open house event must be like heaven for everyone of us... and hell for the credit card and bank account.
I would like to have been there...
KInd regards
Andi
I had a phenomenal time at GEC yesterday. Bill Howard himself gentled the spring on my 25 Jack's secondary blade (although I didn't realize who "Bill" was until after he'd walked away with my knife). He later explained exactly what he'd done, so what exactly did he do? and why he didn't recommend that he try to loosen the tiny coping blade on my new 26, and what to try instead. and what was that?
~ P.
Share the knowledge
Share the knowledge
I was afraid someone would ask; Mr. Howard's explaining it and my understanding the explanation aren't exactly the same thing!
With the 25 jack, he said he put the knife in a vise and used a slim file(? shim?) to slightly ease the pressure right at the pivot point. Or at least, he did *something* with a slim file that did not include what I would have attempted, which was addressing the tang or the back of the spring directly.
Unlike with the small blade on the Jack, the coping blade on the 26 sits on the same spring as the main blade. And a thick main spring it is (just realized I don't have a direct picture of the offset coping blade on the spring):
He explained that anything he did (to the spring) to ease the small blade would affect the main blade as well, and since its action was right where one would want it to be, he was hesitant to do anything to the knife-- especially since he was able to open both blades seemingly effortlessly!
In addition to oiling and working the joints (the former of which he did for me), he recommended leaving the blades partway open overnight and/or when not in use to keep tension on the spring.
I'd read about that possible measure before in reference to other knives with stiff pulls and wouldn't think it would work, but he thought it might make just enough difference over time that other measures wouldn't be needed.
Even after expressing his hesitation, he was still willing to work at the pivot/spring if I wanted him to. I decided to go with his recommendation instead (what say). So, I'm going to give it time, elbow grease, and partially-open overnights, and see what comes of it.
... Watching him open both blades so easily was both eye-opening and frustrating! It was worth it, though, to see my new knife in its creator's hands, and how expertly he handled it.
~ P.
Pertinux, the point on the backspring right at and a bit forward of the center pin is where most of your spring tension is. To relieve some of the tension you just need to remove a bit of material from the spring at this point. That's likely what Mr. Howard did from the sound of it. You have to be careful, it doesn't take much to make the spring too weak, which is why he likely didn't want to mess with the 26, what you remove from one spring has to be removed from the other as well. Normally when a knife is assembled the springs are oversized and stick up above the brass scales (talk about a nail breaker!!). When it's ground and hafted the object is to grind the springs down to the scales and stop there, that's generally where the ideal spring tension is, or at least where it was designed to be. Sounds like you had an incredible time, can't beat a one on one tour!!!
Eric
Pertinux, the point on the backspring right at and a bit forward of the center pin is where most of your spring tension is. To relieve some of the tension you just need to remove a bit of material from the spring at this point. That's likely what Mr. Howard did from the sound of it....
Eric, thanks-- that sounds like what he was trying to explain to me.
And you're right, it was a fantastic time, and the tour was the best! Not only was Mr. Vroman great, but the people working on the knives were very gracious about being interrupted left and right, and if they saw me later asked if I enjoyed my tour.
A very good day.
~ P.
Holy cow, now that's a tour! Sorta like a tour of Case with William Russell Case himself (well, you know what I mean).
I am going to make it a point to get out there next year no matter what.
That #25's a keeper now P!! Thanks for the info and Eric for the explanation.
Hey Guys, I just got back from the Rendezvous yesterday and I had a great time!!!
I got a few pics, but nothing too great, I'll get them off the camera and get them on here ASAP.
I got a couple knives too, I'll be sharing shortly.
I'll get a good writeup on the weekend soon
I'll get a good writeup on the weekend soon.
Sounds good, Johnny.
Did you happen to still be there when the winner for the Wounded Warrior knife was drawn? I'm hoping GEC posts how much money was raised....
~ P.
