No sarcasm here. I think it's truly fascinating that (apparently) you have to be able to pass a 90 degree bend test as a part of your journeyman test. I'm truly curious as to what this test is measuring.
Ok. My bad. Here's a link to the JS test from ABS; the test is explained there:
http://www.americanbladesmith.com/ABS_JSTest.htm
And here's a link to Crucible's web site offering info on S30V, including a toughness/wear resistance graph which offers comparisons to other steels, including D2 and 154CM:
http://www.crucibleservice.com/datash/dsS30Vv5.pdf?CFID=1816476&CFTOKEN=90696595
As for S30V being brittle:
"Although the longitudinal toughness for all three of these grades is about 25-28 ft. lbs., the transverse toughness of CPM S30V is four times greater than that of 440C or 154CM. These higher transverse toughness results indicate that CPM S30V is much more resistant to chipping and breaking in applications which may encounter side loading. In knifemaking, its higher transverse toughness makes CPM S30V especially good for bigger blades." --Crucible
Even the most advanced steel is only as good as it's heat treatment.
Noss, do all of your tests show pretty much the same results for S30V knives??
