Sorry, this is a long one, but it is safety-related, so I hope some of you will indulge me...
I'm just starting out in knifemaking. I decided to use a 4 x 36 bench sander at first, and if I keep up with it (i.e., get 3 or 4 knives complete, and want to keep going) then get a KMG.
So far, I'm finding the grinding process discouraging -- the 4 x 36 can't get a clean plung at all on the left side (can't even get the belt over to the edge of the platen), and a poor one on the right, and the belt is so wide I have difficulty with getting a clean flat grind (heats up so fast). I use files to fix it up after grinding.
I've researched the "Grinder" threads here extensively, and I know that a KMG would greatly help in my learning to grind well.
My problem is that I am a newby with power tools too (only ever used a hand drill before this), and I'm having a hard time maintaining proper "safety-consciousness" while grinding. Several times I've caught myself lifting my face shield to look at lines, then going back to grinding without lowering the shield. I've also caught myself doing "contortions" to try to get the plunge by the ricaso to take, and then realized that I could have ground off a knuckle or worse.
A KMG, being much more powerful, is far more dangerous. I like to think that some of my unsafe manouvers will disappear out as I develop proper shop habits, and that most of them result from the frustration of trying to get good grinds on a machine designed to sand blocks of wood -- but I worry that if I get a KMG I'll always live in fear of it, and end up giving up on knife-making (note: I and not an accident-prone person, but my hands are my lively-hood and I don't want to mangle them).
Has anyone else moved from a 4 x 36 (or 6 x, etc.) to a "real" knife-maker's grinder? Did you find that the real grinder ended up safer, because it would do what you wanted? Or did your methods (good or bad) just get transfered to the new grinder?
