Using used belts for profiles is a great way to justify junking the belts sooner. Profile with old and use the new fir the bevels.Did you cut out blanks or just profile from rectangular stock??? That makes a difference on Belt Life. Cutting a blank close to dimension will give you less to grind and belt should last 20-30 profiles(36 grit ceramic).
Since these are your first Blanks to Grind and you have a bubble jig stick with Flat Grinds. I would concentrate on basics not chasing a Hamon that should come after you perfect your grinding skills. Once you can control a good flat grind even on both sides of the blade then you can try hollow grinding which take a little more control to get good even hollows on both sides.
I get that....but if you use the belt to grind the Entire Profile from a rectangular bar stock to Finished profile in lieu of cutting a blank within 1/16" or less of finished profile. My Question was: Did he cut the Blank with a saw first or Grind it all to dimension?? Huge difference in the amount of Belt Wear.Using used belts for profiles is a great way to justify junking the belts sooner. Profile with old and use the new fir the bevels.
You didn't ask this, but instead of 5 different designs, try 30 of the same pattern and an easier grinding steel.
Repetition and perfection on the same thing until you move to something different.
I consider 36 grit too coarse for me. If you're profiling with it - it's way too easy to strip the grit.
The first time I profiled, I could feel the grit flying off and hitting me in the face however it wasn't a ceramic belt.
That process eats belts quickly...I understand the excitement of getting started and you know now how expensive using beltsBusto, I profiled basically from rectangular stock...cut some excess off with a grinder, but After I screwed up and put a groove in one of them I decided to just profile from rectangular stock. I was too excited to get going on the 2x72.
R Randydb , you need contact wheel for profiles , flat platen behind belt don t like to grind thin steel...With contact wheel and right speed you can profile hundred knifes like that /from rectangular stock / on your first picture with one belt . . . .I do have a micrometer.
I considered doing all the same profile. It makes sense to do the same profile over and over again until I am able to be consistent. I also know that taking more knowledgeable people's advice is really wise. Too late for that one, but I do plan to begin with 60 grit and do flat grinds. 60 grit doesn't go wrong quite as fast if I am screwing up but still will cut pretty quick.
Fred, thanks for the support and willingness to help with your number if I need to call. Obviously you want your customers to be successful and not just purchasers. I plan to post pictures when I am done grinding.
I don t think that 36 grit belt is best choice for profiling / maybe WORN one properly fractured not glazed / thin blade . Especially not on flat ceramic plate behind belt .Try higher grit and you would be surprised...On which speed you run your new grinder ?Hi,
One other question. I profiled these using a 36 grit belt. How many blanks should I be able to profile before a belt is done. I can see this one is done after 8 profiles....probably should have been changed after 7 as the last one was a lot slower and hotter as I did it.
Thanks, I am pretty excited about grinding bevels!View attachment 1094187
It was sort of exciting to watch how quickly the belt took the excess steel off. Took less than 5 minutes a blade to profile.That process eats belts quickly...I understand the excitement of getting started and you know now how expensive using belts
that way can be.
Happiness is a new 36 grit belt!
I grind the entire profile from a rectangular bar stock and have no problem profiling a couple dozen blades with a belt. I like using a 60grit way better, the 36 grit is like getting sandblasted. I could probably profile a blade like that in 2 mins with a used belt. Now if I could just get good grinding the bevelsYou didnt say what kind of belt you were using, I use 3m ceramic belts and could profile give or take 25 on a belt.
Are you using the 984f belts by 3M? I like all their belts, they all seem to track well.I grind the entire profile from a rectangular bar stock and have no problem profiling a couple dozen blades with a belt. I like using a 60grit way better, the 36 grit is like getting sandblasted. I could probably profile a blade like that in 2 mins with a used belt. Now if I could just get good grinding the bevels![]()
I have a respirator, hearing protection and face shield over my reading glasses when I grind.
Fred.Rowe I was using an orange 60 grit Norton belt. Why does it matter if you do the ricasso before or after grinding?
I understand what distal taper is, but I am going to hold off doing that yet.
