- Dec 26, 1999
Practice, Practice, Practice..... you get the picture. Yes, using some type of jig is useful, but with practice you can fix any flaws without the use of jigs. Even on a grizzly. Good luck!
You can control the speed on AC motors too. KMG switched over to an AC setup a while back because of reliability issues.I do everything freehand (no problem with those who don't, no biggie) but I've learned a few things through the years.....
1... Wheels, have a variety of them in different durometers.... A 90 durometer 12 inch wheel sucks ass for a sweeping grind with a gradiated plung.... A 60 durometer 12 inch wheel kicks ass for the same aforementioned grind....
2.... Do it backwards.... In other words, start from the tip and go back, this will allow you to get a channel, then move it backwards to a point.
3..... Get a DC motor so you can control the speed.... That's the only major problem with less expensive upright grinders.... they have one speed, haul ass.... Even if you get pulleys on some of them, it's a pain to change it.... However, isn't the Grizz a direct drive? Not sure, just asking...
4...... Get it finished, then go back a few days later and look at it again.... Anything looks good after you look at it for freaking ever..... That's why a knife you finished 1 hour ago will look totally different to you a week/month/year from now.....
MT
The guides work well for hollow grinding.
My VFD setup is a 1.5 HP motor that runs on 110V power.Yes, but the way to do that is with a VFD & a 3 phase motor....and good ones are expensive, more so than a DC motor and controller.
I used a VFD and a 3 phase for a while, but it was more cumbersome than a DC motor and knob controller for me...
DC motors and controllers are pretty affordable on Ebay, that's where I buy mine. I got my Dayton motor/controllers (1.5 hp high torque) for around 150$ + shipping per set.....
You can also use dampening controllers, but you'll lose power from that as you decrease the speed (which is decreasing the hertz and voltage to the motor to control the speed).
MT
A high torque 1.5 hp motor will outdo a 2-3 hp low torque model...
MT
