I am making blade out of CPM 10V. It is prety hard to do with generic sanding belts so I try to use circular wit diamond disk for ceramik. Any comments?
Thanks, Vassili.
There are also people who try and clean loaded firearms!
Only difference is instead of a 2x4 shooting and breaking ribs, you get impaled with a semi pointy blade @ 100mph (uncomfirmed). and also there is the concern of side pressure on a fiber cut off disc. They are not designed for that, unless you get one of the thick ones actually designed for side pressure, and a bunch that I have seen are arbor mounted for die grinder use.
This is steel disk without teeth - flat with microscopic diamonds (Husky made) to cut ceramic (CPM 10V has 25% of vanadium carbides, so it is almost ceramic and so usual abrasive will not work well on it - for this reason not to many people make knives with CPM 10V or 15V). I do not think it will grab the blank I am working with, plus saw has steel cover as usual and only part which do the cut is open.
The way I am using it - small unfinished cuts, strictly perpendicular to saw disk, so it is how it suppose to be used and no any side pressure on disk or something. I move it very slowly down as I get used to do to cat dence hardwood. I think to make bunch of this parallel cuts to form primary bevel - will be slightly hollow. I will not move blanc under saw, only make this bite, stop the blade, move blanc 2 mm or so fix it, make another bite, etc... Then finish it with belt.
Thanks, Vassili.
Vaya con Dios.
You're likely to meet him sooner than you think.
Seriously, take up another hobby. Stop using power tools or get some serious training. Your idea is one of the most dangerous and how can I say this nicely? incredibly stupid methods or working steel I have ever heard even in the Internet!
Of course it is your life.
