- Dec 9, 2003
I went and made my own micarta handles for my griptillian. Was alot of work hollowing out the are for the axis lock.
Do you mind posting pictures? I would love to see that or PM them to me please. Thank you.
Sorry, not the best pictures...
I kinda like the hollow "THWACK" sound my large Grip makes when flicked open.
Here's another option for you. Look at the Benchmade 950Rift. It's a little like a large Grip on steriods. It has very grippy G-10 scales, and a nice thin-edged blade that slices better than the stock Grip blade. :thumbup:
Thank you! It gave me an idea. I have some Blue and green g10 laying around. I will have to play with it when I have some time (found out recently how difficult G-10 is to work with).
I found that g10 is not the easiest to grind. I think the glass fibers (there are glass fibers right?) resist abbrasives. I found myself burning the G10 a lot, but maybe that was wrong speed or worn out belts?.
The easy part is screw holes. The harder part is the loop for the axis lock. You have to get it skinny enough so that the axis lock sticks out enough to grab.
The hardest part is the spring in the axis lock. On the inside of the liners you have to hollow out a circular pattern for the omega spring. I used a dremel and a steady hand.
Unfortunately I also lost a spacer hence the bulky piece seen near the end. Unfortunately it is not quite the right size so the handle is just a little off and the mechanism is not as smooth as before, but it works. Also because I curved the handle I am not able to put on a pocket clip. Well I guess I could I just have not tried yet.
I kinda like the hollow "THWACK" sound my large Grip makes when flicked open.![]()
Also, as previously mentioned, there's the new Bone Collector, which is a spitting image of the Griptilian but with a G10 handle.
