I have a HR150A that I got from MSC 8 or so years, ago. Seems to be fairly accurate... The manual I have has a procedure for adjusting... Remove the top cover. On the beam that runs to the dial, forward of the pivot there is a plate that has 2 screws attaching it to the beam and a threaded rod that runs up from the Indenter shaft. DO NOT adjust center indenter shaft screw or nut(manual is very clear on this!). Manual says to loosen 2 fore and aft screws and slide plate forward "a little" to increase measured value, slide rearward to decrease measured value. Tighten screws and perform another measurement, then adjust again if necessary.
I think we've found my problem....
Initially the indentor shaft screw wasn't even touching the indentor shaft. In my initial post this is what I posted about how neither of the pointers were moving on either of the dials(the large one and the small one inside of it with the "red dot"). I read the manual over and over again, went through the steps one by one to make sure I had things right, and nothing.
I tried setting up a factory testing block and pushing it up into the diamond indentor and no movement on the dial. I push it up a little more into the indentor, no movement but I do see the indentor and indentor sleeve move up. I then move the table/block down slowly and watch for any pointer movement on the dial. Nothing. I try this again and push the test block into the indentor until the indentor and indentor sleeve press up and stop. No movement. I never cranked on the table to get it to move higher, I just moved it back down and walked away, pissed off.
At no where in the Grizzly manual did it say anything about not moving the center indenter shaft screw or nut.
So finally I started moving the "small lever" behind the dial. I'm being very careful and only slightly moving it. It doesn't do anything but I can tell it's slightly moving the large pointer on the dial. Only a little bit though, as if it's through vibration. At this point I decided to loosen the nut on what I now know is the indenter shaft screw. I screw the screw downward, towards the indentor. After a few rotations I see movement in the pointers on the dials. The screw evidently was never down far enough to engage anything when the indentor was pushed up into it. I haven't had a chance to mess around with this indentor screw/nut adjustment much at this point. After trying a couple settings I realized I was getting no where and will probably have to wait to get advice with someone more knowledgeable about the machine.
Either way I'm 99% sure now the problem is with the center indenter shaft screw/nut setting is the problem. Again, the Grizzly manual doesn't say a darn thing about this area in my manual. If it did, I probably would be testing blades just fine now.
Anyone have any ideas on how to dig myself out of this hole? It would be immensely appreciated.
