Bill DeShivs
- Jun 6, 2000
I hollow grind on my 8" Grizzly wheel from the left side. Clearance is tight, but it can be done without too much problem.
I do draw-filing all the time Will, but what the dickens is a sen? Some kind of scraper-type-object?
A sen is basically a draw knife used for metal instead of wood.
Guys, would I be crazy to make a flat steel piece to go between the belt and platen, so I could set its width to match the actual belt? Maybe JB-Weld it on there. I know I'd have to at least bevel the head and tail so the belt would drag on it. But it seems like there's enough leeway in the belt tension and it should work... whattaya think? jkf96a, is this what you were getting at? (you posted while I was still thinkin)
EDIT (again)
on those files for cutting plunges (and guard shoulders for that matter) make sure you grind one side flat! Please don't make me explain it, you know what it's for![]()
With all new parts around $900.00 US. I am looking into it now.
