so assuming your guard surfaces are both flat and parallel (2 different things)
and your tang is surface ground parallel
and you used a carbide file guide for the shoulders, finishing with a file, correct?
and you milled a slot in the guard .002 width undersize from the tang dimension and square to your flat and parallel guard surfaces
following these things, you should not have that gap at the shoulders.
done correctly it's water tight with no other sealing required.
But each step must be done carefully and correctly or you will see some gap and it only takes .002 to see it
Hey Harbeer, thanks for the post.
I don't have a mill, but I did drill and file the slot under size, and also used a round diamond "burr" to hollow out a good bit of the guard thickness from the backside of the slot oversized so I only have about 3 mm that actually needs to be fit up. I used a file to open the rest of the way, and then the rest was file a little, check fit, file a little, check fit, etc.
My tang is tapered until about a few mm before the ricasso, but my ricasso is flat and parallel and so is my guard, which I flattened using my disc grinder. I actually bought a digital mic before I started this knife so I could accurately check these things.
I used a file guide and file to square up the tang shoulders, but I finished the very last bit with an EDM stone to leave a finer finish than file and I ran a good straight edge over the file guide and the shoulders a at a few different angles to make sure there was absolutely nothing left proud of the carbide faces.
They are a few things I will do differently on my next with regard to tapering the tang behind the guard and such, but I have checked everything and each time I have come to this point of the guard fit up, there are very tiny gaps between the guard and tang shoulder. Not big enough to any light to really pass through using bright LED lights to check, but enough to create a bit of a shadow which looks pretty obvious to me.
The thing is, I can slightly tap the bottom or top of the guard and the gap on the side I tap will actually close up, while the opposite (spine or choil side) will open up a little bit more.
This led me to believe that my shoulders weren't completely straight inline with each other, so I ended up hand lapping the carbide faces on my file guide to make sure they were absolutely flat, and then I made sure to put some post-its on the ricasso under the file guide too make sure it would not slip while filing them, and cranked it down as hard as possible as well.
I feel like there is something I'm missing, but I will try a few more "file and checks" with the guard slot to see if it helps, but I'm afraid the same thing will happen as last time and there will be actual gaps in the width of the slot and I'll have to peen the face and re-surface it again.
The thing I'm most worried about now is hammering the guard on too hard to try an close the gaps. I honestly can't have the ricasso shoulders mushroom again because the ricasso is short as it can be without looking off, not too mention there would be even less surface area for the file guide to grip if I had to fix re-file them again.
Anyway, it's still a pretty tight fit and takes a few good hits to knock the guard back off, so I'll try to file it a few more times and let ya know how it goes.
~Paul
My Youtube Channel
... (It's been a few years since my last upload)
