- Oct 19, 2011
A couple of thoughts,
A lot of people know about Nick's WIP which is a great resource but Will Morrison's WIP is also excellent. If you haven't read it, find the time. Check page three for guard fit up.
https://www.bladeforums.com/threads/introduction-and-a-wip.1082411/
JB Weld, like other epoxies, works as a moisture seal under the guard. It's pretty strong too and takes about 600˚ to break it loose if you screw up. Don't ask me how I know. It should not be a replacement for a tightly fit guard as you know. With the blade in a vise and tang up I put a ring of the JB Weld around the tang just above the ricasso. Then I fill the guard opening with the epoxy and carefully slide it down the tang trying to avoid the tang dragging epoxy out of the guard slot as much as possible. As the tang drags epoxy out of the hole it will be running over more epoxy from the ricasso side. I set the guard in place with a 2.5lb drilling hammer and a length of PVC pipe. Do not hammer so hard that you are mushrooming parts. I use a larger hammer because it gives me a larger hammer face and the mass allows me to use a lighter swing, if that makes sense. The pipe has been warmed at one end with a heat gun and clamped in a vice enough to squash it into an appropriately sized oval. Leave it in the vice until it cools then touch up the end nice and flat on your 2x72. The PVC is very tough and will withstand a lot of hammering. Once the guard is seated you can clean up the guard face and ricasso with cotton swabs and alcohol. Don't over wet the swab. You don't want alcohol wicking up into the joint dissolving the epoxy. You just want to wipe the excess epoxy away with dry swabs then do final clean up with damp swabs. Keep checking for squeeze out for about 10 minutes and wipe clean.
As far as fit up goes, one tip I got from Nick was to use the belt sander to true up the shoulders. The carbide-faced file guide works great for this application. I have been frustrated in the past trying to square up the shoulders with a file, stones, etc. I'd check the flatness with a fresh razor blade and I couldn't feel any variation from the file guide but somehow it just wasn't perfect. When I started using the file guide against the platen on the belt sander it just worked better. If you have variable speed turn it way down and use something like a 400 grit belt.
The other thing is to get yourself a set of radius gauges. You can't see how the guard and shoulder radii are mating but by checking both individually with a gauge you can get a pretty good idea.
