Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Indeed, dry is sly
ok, maybe I'm not that hip
BUT, I've only sharpened now with the stones dry and use
lighter fluid to clean the pores out, works VERY well by the way
and if need be, to resurface the stones, use a plate glass and
silicon carbide grit and some water to rub the stone on the flat plate
it gets the stone very clean and flattened out for you.
As to the edge on it now, it's a mix smooth/toothy kind of edge
and shaves effortlessly and can catch what I call tree top cutting
of the hair above the skin, if it were a little more toothier of course
it would catch a bit better but my sharpening goes from coarse
to medium, to fine india and then to ceramic and then leather strop
all which aid in getting a very sharp blade.
BUT, all the sharpening in the world doesn't help if the blade is like
a cold chisel, some knives will require to have the blade thinned down
and for such knives, I HIGHLY recommend sending it to the Tom Krein Spa
He can get your knives into an extremely sharp condition that will cut/slice!
here is the set I travel with, actually upgraded to a larger stone but same type;
and the silicon grit, you can get from a lapidary supply store;
I'm telling you, this little knife may well be THE one, it's just so very handy size
and opening mech, it's hard to beat, my only concern right now is how long
the opening mech part will stay together?? I've heard that one guy had it
fly apart but he put it back together with lock tite and all is now well
G2
G2
